I recently acquired an old stock MXQ Pro 4K box with the S905X soc. It boots up CE just fine, but installtointernal does not work because /dev/boot, amondst others, is missing. I think this is due to the fact that the NAND chip that this box contains is not supported. I tried both the normal gxl_p212 dtb file and the nand version. With the version CE boots fine, but with the latter it doesn’t.
Just wondering if this is a known issue. Since this NAND chip has been around for some time now I expected it would be supported, but alas. Or is there somehting else I can try?
