I have installed successfully CoreElect on a T95N with the S905
But now, im trying to install on a H96 Max with the S905X2
I used the LibreELEC.USB-SD.Creator.Win32 to install CoreELEC-Amlogic-ng.arm-9.2.1-Generic.img
and i utilized the g12a_s905x2_4g and renamed it to dtb.img
I boot into android, and run the UPDATE and BACKUP app. I select a .zip file, and click the UPDATE button, which is what i did succesfully on the T95N and it reboot the system, but instead of booting into CoreElec, I get a picture of an android robot with the word “Error” It then reboots back into android.
I have tried both USB slots with the same result
What the heck am i missing?
Thank YOU
