Not sure if this is a kodi specific problem or a coreelec problem.
Through Kodi I run a couple different streams, some being 720p, others 1080p, both are H264. They problems I’ve got as the 720p channels only stream without issues if I turn off hardware acceleration, but in doing so completely slows down the 1080p streams. If I enable hardware acceleration, 1080p streams play perfect while the 720p streams stutter every couple seconds. It’s a real pain to have to constantly switch on/off hardware acceleration depending what channel I’m watching.
Is there any work around for this?
