Hello.
Coreelec don’t see my external hdd usb Maxtor M3 1TB with NTFS.
Pendrive is ok but not hdd. Only led on hdd lighting and vibrate.
What i should do? Help me.
How big is the HDD? You may need to connect via a powered hub since the box may not have enough power on its USB port to power the drive.
it’s 1TB i change my power supply from 2.5A to 5A
I may not matter how many amps your are passing through on the PSU if there is a resistor or regulator on the USB port. The Khadas VIM3L will only pass 800ma on its USB port no matter how big a PSU you use. I would try with a powered hub as suggested to see if its an issue with power or something else
