So I never had issues with my devices until now. So what happen was I tried to watch Netflix from my TV using ARC to return the Dolby audio back to my Yamaha receiver. That has always worked without a problem.
I have a S905 device with coreelec and what I noticed was even with the device OFF, it seems the HDMI port is being hold by the device somehow. If I unplug the device for power or remove the HDMI cable it releases the port and the ARC starts to work again.
If I put the cable back or the power (without actually turn the device on) it will start to hold the port again and ARC stops working once more.
Not sure if this is a new problem or was already discussed.
To Reproduce
1 - With the HDMI from the S905 device connected to the receiver, turn the TV on netflix and try to use ARC back to the HT. It doesnât work for me.
2 - Remove HDMI cable from S905, re-start the tv and all is working again.
Sorry to refloat this post but I have a very similar problem and it is driving me mad.
Not continuously, like the original post, but just at random times, all of a sudden, the audio from the TV to the AV Receiver by ARC stops working and the only way to get it working again is restarting Coreelec. I find this very weird because Kodi is not even part of the direct link between the TV and the Receiver.
I have read more about this being a âU-Bootâ problem. What is U-Boot? Isnât there anything there can be done?
I have tried turning off CEC completely by activating the following lines to the /flash/config.ini:
hdmi_cec=â0â
cec_func_config=â0â
But no luck, Kodi still sort off hijacks the ARC back signal.
I use a Odroid-N2 device with Coreelec 9.2.2, connected to an Onkyo TX-NR686 Receiver which is connected by eARC to a LG OLED C9 tv.
