I have several boxes with S905D (Mecool KI Pro) and with S905Y2 (X96S tv Stick). Recently I installed CoreELEC 19.2-Matrix_rc2 on each of them. The following problem arose. Boxes with S905D do not play files with 4K HEVC HDR10+ (freeze and reboot). Other files with 4K HEVC are played without problems. Boxes with S905Y2 reproduce everything without problems. Any ideas how to solve this problem? Thanks!
Please share a sample and a log to see what’s happenig there.
- Sample file - https://drive.google.com/file/d/1fP1Yfa195EpVsabXvyBcdh5tNl_d3r_Q/view?usp=sharing
- dmesg | paste - http://ix.io/3qy6
- Kodi.log - https://drive.google.com/file/d/1LnOkrOZ2cFBXkFsECgxrcwfawppKp5Fc/view?usp=sharing and https://drive.google.com/file/d/12lop56WCLC0pbPpo2S5EZDP-HLY5zc56/view?usp=sharing
Does it happen with specific HDR10+ files or all of them?
I cannot reproduce the problem with your sample, but your sample is strange in that I see HDR10 BT709 and then it switches over to BT2020nc like it’s supposed to be (my TV does not support HDR10+, though)
I would recommend that you try a clean install on the problematic device and see if the problem persists.
It happen with all 4K HEVC HDR10+ files
Sample2 - https://drive.google.com/file/d/1C3Ph44-ERszKD67edWycumBH-opjAg3-/view?usp=sharing
Sample3 - https://drive.google.com/file/d/1mXF1N2IIdNbzmgGAPNA52AIj7bQj3Sxo/view?usp=sharing
I did a clean install of the system on two devices
If I see well you are using skin.confluence-extended, please try with the default skin, just out of curiosity.
It did not help. It helps to turn off the next parameter - Settings - Player - Allow hardware acceleration amcodec - off. But then it slows down a lot.
Does the box do a full reboot or does only Kodi restart?
If it’s only Kodi, then you should have a crashlog.
If the whole box reboots, then I fear that the only real way we may get somewhere is with a UART log, which could indicate the position of the kernel oops. None of us have a S905D device, and on all devices we have, we do not have this problem.
The box do a full reboot
How can I obtain the UART log?
I have a USB-UART adapter, and I am using it with VIM3. But I don’t know how to connect it to KI Pro. Thanks again!
There are several methods.
- The simplest method we could try to start with is to SSH into the device, run
journalctl -kf
, which will start dumping all dmesg output into the SSH session. Maybe this will allow us to catch thekernel oops
before it restarts. - You can use the CoreELEC Team SDIO Debug Board
- Most boxes have UART pads on the PCB. You can open it and connect your UART adapter to those pads (you only need TX,RX,GND, don’t connect VCC)
Thanks. I started with a simple method, but it didn’t give me anything interesting.
CoreELEC (official): 19.2-Matrix_rc2 (Amlogic-ng.arm)
CO:~ # journalctl -kf
– Journal begins at Tue 2021-02-02 17:29:47 EET. –
Jun 23 20:06:32 CO kernel: snd_spdif_dai: set normal 512 fs /4 fs
Jun 23 20:06:33 CO kernel: snd_spdif_dai: aiu 958 playback enable
Jun 23 20:06:33 CO kernel: snd_spdif_dai: aiu 958 playback disable
Jun 23 20:06:33 CO kernel: snd_spdif_dai: set normal 512 fs /4 fs
Jun 23 20:06:34 CO kernel: snd_spdif_dai: aiu 958 playback enable
Jun 23 20:06:34 CO kernel: snd_spdif_dai: aiu 958 playback disable
Jun 23 20:06:34 CO kernel: snd_spdif_dai: set normal 512 fs /4 fs
Jun 23 20:07:15 CO kernel: audio_dsp: buf=0
Jun 23 20:07:15 CO kernel: audio_dsp: IEC958_mode_raw=0
—REBOOT Box—
Yeah, sadly this doesn’t help.
I’d expect to see an output with errors.
Have you tried a different power supply? Sometimes bad power supply can cause weird issues.
Other than that, we need to follow options 2 or 3, as 1 didn’t give us any useful results.
I have changed power supplies.
I’m trying to order SDIO Debug Board.
I am already wondering.
Received the CoreELEC Team SDIO Debug Board, connected it.
Result - https://drive.google.com/file/d/1CCuvCnpaZBta8Y7iN7WkCSEXpl1coGj3/view?usp=sharing
Nothing
Please set correlec
to
coreelec='nopkmute'
in the config.ini file, reboot and then see if you get proper output in UART console.
Ok.
Here is the new result -
CI:~ # journalctl -kf
[ 64.525290@1] fb: mem_free_work, free memory: addr:800000
WARNING: Unimplemented Sip Call: 0x8200004a
[ 72.582388@3] hdmitx: hw: set audio
[ 72.582432@3] hdmitx: hw: hdmitx tx_aud_src = 0, audio_param->channel_num = 1, hdev->aud_output_ch = 0
[ 72.589606@3] hdmitx: fs = 2, cd = 4, tmds_clk = 148500
[ 72.594727@3] hdmitx: hw: aud_n_para = 6272
[ 72.598897@3] hdmitx: hw: set channel status
[ 72.603183@3] hdmitx: audio: Audio Type: PCM
[ 72.607330@3] hdmitx: audio: set audio param
[ 84.056941@3] VID: VD1 off
[ 84.061874@2] The fw has been loaded.
[ 84.061920@2] vdec_init, dev_name:ammvdec_h265, vdec_type=VDEC_TYPE_FRAME_BLOCK
[ 84.077556@3] [LOCAL], the fw (hevc_mmu) will be loaded.
[ 84.077815@3] ppmgr local_init
[ 84.080481@3] di_receiver_event_fun: vframe provider reg ppmgr
[ 84.087749@3] DI: reg f
[ 84.088717@1] ppmgr local_init
[ 84.093497@2] vdec->port_flag=0x102, port_flag=0x10b
[ 84.166286@1] snd_spdif_dai: enterd aml_spdif_play,set_clock:5,sample_rate=4
[ 84.167724@1] hdmitx: hw: set audio
[ 84.171744@1] DI bypass all 3840x2160-0x501000.
[ 84.171745@1] hdmitx: hw: hdmitx tx_aud_src = 0, audio_param->channel_num = 1, hdev->aud_out
—REBOOT Box—
One more attempt -
CI:~ # dmesg|paste
http://ix.io/3sXn
CI:~ #
[ 93.896910@1] hdmitx: hw: set audio
[ 93.896957@1] hdmitx: hw: hdmitx tx_aud_src = 0, audio_param->channel_num = 1, hdev->aud_output_ch = 0
[ 93.904216@1] hdmitx: fs = 2, cd = 4, tmds_clk = 148500
[ 93.909391@1] hdmitx: hw: aud_n_para = 6272
[ 93.913479@1] hdmitx: hw: set channel status
[ 93.917676@1] hdmitx: audio: Audio Type: PCM
[ 93.921865@1] hdmitx: audio: set audio param
[ 94.060143@0] VID: VD1 off
[ 94.063559@0] The fw has been loaded.
[ 94.063613@0] vdec_init, dev_name:ammvdec_h265, vdec_type=VDEC_TYPE_FRAME_BLOCK
[ 94.079814@3] [LOCAL], the fw (hevc_mmu) will be loaded.
[ 94.080121@3] ppmgr local_init
[ 94.082651@3] di_receiver_event_fun: vframe provider reg ppmgr
[ 94.089911@2] DI: reg f
[ 94.091715@2] ppmgr local_init
[ 94.096368@1] vdec->port_flag=0x102, port_flag=0x10b
[ 94.164560@1] DI bypass all 3840x2160-0x501000.
—REBOOT Box—
Is this the UART log?
Yes exactly
