journalctl -l | paste
https://paste.coreelec.org/SailboatMusical
Mounting in rclone without system.d services also produce empty folder for the megadpd & megawabb.
Iām affraid you will have to debug this on your own because no one else can replicate this issue. Unless you send me config in PM.
Sure, rclone.conf & .service file?
I think rclone.conf is enough because auth data is already there? And command to execute in terminal.
I installed Entware via the āinstallentwareā command under coreelec 21 ne and installed rclone and fuse via the āopkg install rcloneā and āopkg install fuse3-utilsā commands, respectively. See rclone and fusermount3 binaries under the /storage/.opt/bin folder. Then deploy Alist via rclone config.
Finally, enter ārclone mount Alist: /storage/Alist --use-mmap --umask 000 --network-mode --no-check-certificate --allow-other --allow-non-empty --dir-cache-time 4h --cache-dir=/storage/ .config/rclone/cache --header "Referer:" --vfs-cache-mode full --buffer-size 512M --vfs-read-chunk-size 64M --vfs-read-chunk-size-limit 2G --vfs-cache-max-size 5G --daemonā was successful.
However, there is a problem with configuring boot auto-start. I created rclone.service in the ā/storage/.config/system.dā folder and entered the relevant code, but it doesnāt start successfully
[Unit]
Description=RClone Mount
After=network-online.target
[Service]
Type=simple
Environment=PATH=/storage/.opt/bin:/.opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
ExecStartPre=/bin/mkdir -p /storage/Alist
ExecStartPre=/bin/mkdir -p /storage/.config/rclone/logs
ExecStartPre=/bin/mkdir -p /storage/.config/rclone/cache
ExecStart=/storage/.config/rclone/rclone mount \
--log-file /storage/.config/rclone/logs/rclonemount.log \
--log-level INFO \
--allow-root \
--allow-other \
--allow-non-empty \
--header "Referer:" \
--network-mode \
--no-check-certificate \
--tpslimit 10 \
--tpslimit-burst 10 \
--dir-cache-time=48h \
--buffer-size=512M \
--attr-timeout=1s \
--vfs-cache-mode full \
--vfs-read-chunk-size=64M \
--vfs-read-chunk-size-limit=2G \
--vfs-cache-max-age=5G \
--vfs-cache-mode=writes \
--cache-dir /storage/.config/rclone/cache \
--config=/storage/.config/rclone/rclone.conf \
--daemon \
ExecStop=/bin/fusermount -uz /storage/Alist
Restart=on-abort
[Install]
WantedBy=default.target
Did you even look the log and search for rclone lines?
Apr 12 09:10:22 CoreELEC rclone[854]: Error: invalid argument "5G" for "--vfs-cache-max-age" flag: parsing "5G" as fs.Duration failed: parsing time "5G" as "2006-01-02": cannot parse "5G" as "2006"
is not valid - this is time not size.
Thanks.The reline code has been revised, but another problem has arisen
systemctl status rclone.service | paste
will tell more
Looks ok to me:
code=exited, status=0/SUCCESS
Sorry, I forgot that I mounted it manually. Iāve restarted the machine now, and it still doesnāt work, hereās my newly acquired diary.
https://paste.coreelec.org/WannabeClumsy
Nothing obvious visible.
If you want enable terminal sharing and I will look myself.
