roidy
1
I just got a Zidoo V10 Bluetooth remote:-
I can pair it fine but only about half of the buttons work, the most noticeable one that doesn’t work is the center select/enter button.
I followed this wiki page remote:rr_bluetooth [CoreELEC Wiki] for creating a hwdb config, evtest detects the ok button and reports it as c0041
I created this hwdb file:-
# Zidoo V10
evdev:input:b0005v2b54p1600*
KEYBOARD_KEY_c0041=enter
KEYBOARD_KEY_c01bd=i
Then ran:-
udevadm hwdb --update
udevadm trigger -s input
reboot now
But the buttons still don’t work, any help please.
roidy
2
Typical… 2 minutes after posting I figure it out.
If the Bus, Vendor, Product or Version is a hex value that contains a letter then it needs to be uppercase.
evdev:input:b0005v2b54p1600* - fails
evdev:input:b0005v2B54p1600* - works
This information should really be in the wiki to save others running into this problem.
Thank you for letting us know. Our WiKi content has been updated accordingly.
roidy
4
@Betatester Thanks
There’s one more small error on that page, in the save changes to the database section:- remote:rr_bluetooth [CoreELEC Wiki]
The first command is missing an extra ‘-’ minus sign:-
udevadm hwdb –update
should be
udevadm hwdb –-update
Yeah that is interesting because markdown is clearly set to use preformatted text:
''udevadm hwdb --update''
yet it shows as – a solid line. Might be the font used by the browser.
Solved by marking the text block as sourcecode to avoid confusion.
system
Closed
6
