I have a HK1 BOX with only CoreELEC installed on EMMC/NAND.
Is it possible to boot from ssh to armbian written on an SD card?
I’m looking for a command line to do that.
Maybe question for Armbian forum?
But I’m running CorelELEC and I want to issue a (reboot update) equivalent command.
If you have SD card inserted it will boot from it.
But from what I read Armbian is not compatible with default boot methods CoreELEC is using. That’s why people at Armbian can help you more because I doubt anyone here is using Armbian.
So if I write EmuELEC on the SD card and power cycle the box will boot to EmuELEC?
What about manjaro for arm?
Yes.
No idea - same as with Armbian. Why not try and see what happens?
Thanx,
I’ll do that and report back here.
EmuELEC worked.
Manjaro 21.03 for vim3 didn’t work.
Thanx again
