i am getting this screen for few seconds before Coreelec 22 RC1 boot logo appears ,My device equipped with S905X4-J., KINDLY HELP ME ON THIS
HELP US!!!
Dear Team
CoreELEC Version: CoreELEC 22 (Piers / RC1) Comparison: Issue does not occur on CoreELEC 21.3 Omega (clean boot with no static)
Device Information
- Brand / Model: Dune HD Pro Vision 4K
- SoC: Amlogic S905X4
- Memory Size: 4GB RAM (3648MB reported)
- Board Type: Amlogic SC2 Reference Design (S905X4)
Peripheral Information
- Display: Sony A80K OLED (4K UHD)
- Receiver / AVR: Denon AVR-X2800H
- Sound System: Multi-channel surround system connected via AVR
- Wiring / Cabling: Certified High-Speed HDMI cables (Dune HD → Denon AVR-X2800H → Sony OLED eARC/HDMI input)
- TV Tuner: None
Boot Method
- Boot Medium: USB Flash Drive
Description of the Issue
When performing a cold boot from power-off, a full screen of static digital noise (“snow”) appears for approximately 2 to 3 seconds before the CoreELEC kernel takes over and displays the GUI.
- On CoreELEC 21.3-Omega (Amlogic-ne / 5.4 kernel), cold boot transitions smoothly from the Dune logo to Kodi without any static.
- On CoreELEC 22 (Piers / Amlogic-no), the screen flashes full static during early initialization.
- Once booted into Kodi, video and audio playback are completely stable (Dolby Vision Profile 7 FEL with DV-Std tunneling and DTS-HD / TrueHD Atmos bitstream passthrough work without issues).
- Adjusting config.ini parameters (vout, color depth, and color space) does not eliminate the flash, indicating an early HDMI PHY/transmitter clock reset before stage-2 boot.
(Attached: Photo of the static snow during cold boot)
Update Android on the device.
Thank you for clarifying, @Portisch. I understand that CoreELEC relies on the vendor’s U-Boot and HDMI bootloader stages in eMMC.
My Dune HD Pro Vision 4K (tv184a) is already flashed to the latest firmware available from Dune: dune_firmware_tv184a_260220_1945_r24.dff (from their latest r24 branch). There are no newer builds provided by the vendor.
Even with this firmware, the 2-3s HDMI sync/snow flash persists during early boot on CoreELEC 22 (Amlogic-no / DRM-KMS), while CoreELEC 21.3 Omega booted completely clean.
Since the device is on Dune’s newest available software, is this an unfixable limitation of Dune’s vendor U-Boot when handing off to the modern display driver, or would you like me to pull a dmesg log to inspect the HDMI PHY handover?
I have the same snow on the same box. It never occurred to me that this might be an issue - does it actually bother you at all? And why perform cold starts in the first place? For me, those only happen after updates or a power outage. There is no snow when you only stop/start Kodi…
Thanks for confirming, @dmitry1988! That’s really helpful to know it’s reproducible across other Dune units on CE 22.
It doesn’t break playback once Kodi loads, but because CE 21.3 Omega boots with a clean black transition from the Dune splash, the sudden burst of static on a cold start stood out as a noticeable regression in the early display handover on 22 RC1.
On the other hand, with version 21.3, about 1 out of every 10 boots would result in acid, distorted colors- an issue that could only be fixed by rebooting again. Version 22 doesn’t have this problem at all. That’s a far more annoying issue than the snow. In any case, it’s better to use sleep mode rather than shutting down completely every time; it’s much faster.
But I am using Dune Alpha OS means Beta does it make any sense?
I don’t know. I never boot DuneOS. CE is much better in every way for how I use it.
Why are these issues reported in the Homatics topic? The device has no relation with it at all, not a Google certified Android TV device, not a S905X4-K device.
Same here: Amlogic-NO discussion - #4063 by Portisch
Hello everyone. I’m still having trouble with CoreELEC on my Dune Homatics 4K Plus; I just can’t get it to work. I even tried installing the version specifically designed for Android 4. The Dune detects the flash drive and begins the boot process, but it gets stuck at the CoreELEC logo. I’ve tried every solution I could find, and now I’m considering installing the Android 11 or 12 version instead. Could you help me find the correct file? Thanks for your help.
Use sc2_s905x4_sei_smb_280
I used this `sc2_s905x4_sei_smb_280` and it doesn’t work; I think the problem is the kernel, which is blocking CoreELEC.
Have you tried a different flash drive?
What already is suggested. Brand and model storage used can be very critical for CE boot.
I’ve tried three—a cheap one, an SKK, and the Samsung FIT Plus—and there’s absolutely no difference.
Sorry for asking such basic questions, but your statement that you’ve already tried everything doesn’t tell us much.
So, what exactly have you tried?
I’ve followed every guide I could find and tried the specific file for ATV 14 that I was given here; with this file, I reach the CoreELEC splash screen, but then the box crashes. I also bought the flash drive that was recommended to me, but that didn’t help either. I’m now considering going back to Android 12.
