yes…but the signal / command comes from my Harmony one+…but i have used rasp with LE incl. this Harmony since 5 years…there wasnt this situation. i have to search after “deactivating the suspend modus”
I asked few times and never got answer: do you even know when it freezes? Just at random interval, when pressing some buttons, …
I think you are expecting to make your setup perfect without investing much own time into.
I had answered each time and basically I’m already investing hours in it that it finally runs well and reliably.
I also said that when Harmony “turns off” the action is that it then “freezes” when it turns on. Even if I’m out for 1-2 hours and then I want to bring back the TV and the Dune - just press a button to bring it out of standby - there’s a freeze. Without any action such as actively pressing a button - only for waking up.
In no case do I take the easiest way to get the setup sorted out. On the contrary. Maybe it’s also the CE.
when I restart Ce it always freezes, my plan was to create a log file but how will that work in this case?
Copy kodi.log and kodi.old.log manually from lol g folder. Enable Kodi debug before! Then you will also see the location where the log files are located.
kodi.log (1.6 MB)
Not so easy, every time I want to make an error log comes the message (Faild to paste log files, try again).
I don’t get a URL log but it is in the directory but the file is 18 MB and can’t be uploaded.
Like the Movie Database Python scraper, there are also only error messages.
The system is rebuilt, the first times it works with the restart but after a while no longer, always freezes in the shutdown menu.
The 4k60 GUI mode switch to 4k60 dolby vision still a work in progress?
It should be solved already with last nightly.
Something looks wrong, it still pick 420 because of 4k60hz, this should be ignored because of DV.
EDIT,
ah maybe I know the error. cd & cs is checked for 0 and skip mode switch.
But 0 is a valid value… Will test it next week.
On my Panasonic Oled no such a problem. Gui at 4k60 mode and DV is perfect. Same on the Lg C2.
Just for your information.
Just wanted to say, KUDOs to all of you Devs…
Just tested a UHD Rip of Back to the Future with Dolby Vision, and it plays perfectly., Outstanding work by you guys. This is using the Dune HD Homatics Box R 4K Plus
Back to the future with dv?
How does it look like? ![]()
I already had the Blu-ray version, but the 4K looks and sounds fantastic.
so after going back and forth with homantics i did get the recovery image. so what is needed to get coreelec installed to emmc?
Is it official shared by Homatics? If not what will do the other hundred users with internal install? With internal install you are not able to update Android. So this FEL issue can not be solved at all.
it’s not on their website no, it was sent directly to me. i guess i don’t understand, why can you not make a special image for the homantics box with the updated dovi files when fixed?
WHY do you guys keep linking this post? my question is not asked nor answered in there
Then you did not read it completely or not carefully enough. We link to this post so we don’t need to type again and again the same answers.
