Homatics Box R 4K Plus
http://ix.io/4lc3
I only tried with nexus.
http://ix.io/4lch Nexus buzztv dtb
http://ix.io/4lcj Matrix generic dtb
Matrix is final, so only fixes will be merged in future.
Go with ce-20, Nexus.
Ok. You will made fixes for this box, like as separate dtb?
Please try with this dtb on Amlogic-ne if LAN do work. If yes please run dmesg | paste so we can go further to Wifi.
sc2_s905x4_4g_1gbit.dtb (66.0 KB)
http://ix.io/4lmr
can you bring the device online tomorrow morning with tmate so I can make more debugging and try to get the reason and how to correct implement the patch?
Yes I can, Thanks
Are you ready for tmate invite?
tomorrow, at lunch time
@rome1931 you can start now the tmate session.
I won’t be home for another 6 hours.
you will need to have it switched on during the day…
Ok safe to leave on?
https://wiki.coreelec.org/coreelec:term_share#establish_a_support_session
Session started if you’re available.
again tomorrow… :frowning:
Ok I got a way to make it work while I’m gone
Looks like your device have a ethernet chip: Motorcomm YT8531C
Maybe this is required to add:
https://lore.kernel.org/netdev/Y0TMIMPJbOETFQ3f@lunn.ch/T/
