Homatics Box R 4K Plus
What was your route to requesting the new firmware via support ?
I asked the Homatics support when the new firmware will be available.
They answered me today:
“Start pushing out today and needs about 1 week to reach everyone.”
I was already able to perform the update.
I received the firmware 5310 yesterday for dune also…
Any .5310 news from nokia users?
A sample video made using DoVIBaker, Fel layer is baked into BL and RPU is converted to 8.1.
No Update yet
and Dolby Vision in CoreElec works for you, because not for me in firmware 5310
I just used the webform on the website.
Don’t know for sure… My old Philips OLED don’t support Dolby Vision… HDR10 is working.
Sorry, can’t help…
Just updated nightlies, got a warning about Android firmware being incompatible with Dolby Vision, went into Android and it flashed for a split second no updates but then started downloading an update with a hilariously detailed filename.
Had to do the reset trick to get back into CoreElec again, but it all seems to be working.
Unrelated: why is it that Dolby Vision movies usually look like crap in HDR10, while HDR10-only movies tend to look a ton better?
is there anyone who has Dune firmware 5310 and can’t do Dolby Vision in coreelec 21.0-Omega_nightly_20230705
Runs perfectly
it already works, wrong img.dtb
Hi
For me also the DV format did not work under CE after updating DuneHD. The solution was to delete the dtb.img file that was previously on the USB. Then I copied the sc2_s905x4_sei_smb_280.dtb file from the device_tree folder of a current img file and placed it as dtb.img file to USB.
Maybe did the dtb file changed
in the meantime and I had the old on my USB?
Have a Homatics R 4K Plus - rebooted into Android today, received the OTA update, rebooted into CoreElec using toothpick method, accepted the nightly download, installed it, and have DV files playing fine.
Whenever I reboot coreelec on my dune hd homatics box it reboots in android tv. Am I doing something wrong? Coreelec is on a usb flash drive on the usb 2 port.
I have similar problem . I recently purchased the box and fortunately got 5310 fw immediately. I was able to boot into coreelec but I powered off my devices from switch and when I went back it goes into atv . Also next time green screen until I booted again in coreelec but this time I rebooted to android from coreelec menu just to check
What are best settings to ensure system stays in last powered state be it atv or coreelec ?
Also kindly share best setting both in atv mode using dune app as well as coreelec kodi for proper audio video formats
I also saw inside dune app it says either chose internal player or Sfmc/kodi what is that ?
Annoyingly my Homatics box isn’t offering me any updates
They paused again to solve some problem related to the tuner. They’ll resume in the beginning of the week.
