cmd:PROJECT=Amlogic ARCH=aarch64 DEVICE=AMLGX make image
print info:
./scripts/image mkimage
Configuration for CoreELEC (community)
Buildsystem configuration:
- CPU (ARCH): cortex-a53 (aarch64)
- FLOAT:
- FPU:
- CPU features: 64bit neon
- LTO (Link Time Optimization) support: yes
- GOLD (Google Linker) Support: yes
- LLVM support: no
- DEBUG: no
- CFLAGS: -march=armv8-a+crc+fp+simd -mabi=lp64 -Wno-psabi -mtune=cortex-a53 -mno-outline-atomics -Wall -pipe
- LDFLAGS: -march=armv8-a+crc+fp+simd -mtune=cortex-a53 -Wl,--as-needed
Misc. hardware configuration:
- ALSA support: yes
- Pulseaudio support: yes
- Bluetooth support: yes
- Include firmware: dvb-firmware
- Include firmware: brcmfmac_sdio-firmware
- Include firmware: kernel-firmware
Misc. Filesystems:
- Swap Support: yes
- Swapfile default size: 128
- exFAT Support (via Fuse): yes
- NTFS Support (via Fuse): yes
- Install HFS Tools: yes
Network service configuration:
- Avahi (Zeroconf) support: yes
- NFS mounting support: yes
- SAMBA mounting support: yes
- SAMBA server support: yes
- SFTP server support: yes
- OpenVPN support: yes
- WireGuard support: yes
Graphic configuration:
- OpenGL (GLX) support (provider): no (no)
- OpenGLES support (provider): yes (mesa)
- VAAPI Support: no
- VDPAU Support: no
OS configuration:
- OEM Support: no
- Default ROOT Password: coreelec
- Bootloader: u-boot
- UDevil support: yes
- Installer support: no
- Include package: dtc
- Include package: ethmactool
Kodi Hardware configuration:
- Video Acceleration provider: mesa
- Remote support: yes
- CEC Adapter support: yes
- CEC Framework support: yes
- Kodi Joystick support: yes
Kodi Software configuration:
- Kodi Blu-ray support: yes
- Blu-ray BD+ support: yes
- Blu-ray AACS support: yes
- Kodi DVDCSS support: yes
- Kodi Airplay support: yes
- Kodi Airtunes support: yes
- Kodi NFS support: yes
- Kodi MySQL support: mariadb
- Kodi Optical Drive support: yes
- Kodi SAMBA client support: yes
- Kodi UPNP support: yes
- Kodi Webserver support: yes
- Include Skin: Estuary
- Default Skin: Estuary
- Include extra fonts: yes
End Configuration for CoreELEC
File "scripts/genbuildplan.py", line 370, in <module>
REQUIRED_PKGS = processPackages(args, ALL_PACKAGES)
File "scripts/genbuildplan.py", line 299, in processPackages
raise Exception(msg)
Exception: Invalid package reference: dependency CoreELEC-settings in package mediacenter::PKG_DEPENDS_TARGET is not valid
Parallel build failure - see log for details. Time of failure: Mon Mar 15 02:15:42 PDT 2021
Makefile:12: recipe for target 'image' failed
make: *** [image] Error 1
Has anyone encountered this problem before?
