Thanks for the continued help.
I ran ./scripts/build linuxwith no changes to the source since it had previously been run, it completed more or less immediately and returned with no output.
I then modified directly modified amdv.c in the build.CoreELEC-Amlogic-no.aarch64-22 folder with the print statement. Removed the stamp file rm build.CoreELEC-Amlogic-no.aarch64-22/.stamps/linux/build_target and built with ./scripts/build linux. The last command took a little over a minute, but I did not see build statistics as you showed at the end of the build.
The end of the output (start truncated by the size of the terminal history / post limits) is:
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv4/udp_diag.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv4/udp_tunnel.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/ah6.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/esp6.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/ip6_udp_tunnel.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/ipcomp6.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/netfilter/ip6_tables.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/netfilter/ip6t_REJECT.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/mip6.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/netfilter/ip6table_filter.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/netfilter/ip6table_mangle.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/netfilter/ip6table_nat.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/netfilter/nf_defrag_ipv6.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/netfilter/nf_reject_ipv6.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/sit.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/xfrm6_tunnel.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/ipv6/tunnel6.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/key/af_key.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/l2tp/l2tp_core.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/l2tp/l2tp_debugfs.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/l2tp/l2tp_eth.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/l2tp/l2tp_ip.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/l2tp/l2tp_ip6.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/l2tp/l2tp_netlink.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/l2tp/l2tp_ppp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/llc/llc.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/ipvs/ip_vs.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/ipvs/ip_vs_ftp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/ipvs/ip_vs_rr.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_conncount.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_conntrack.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_conntrack_broadcast.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_conntrack_ftp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_conntrack_netbios_ns.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_conntrack_netlink.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_conntrack_pptp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_conntrack_tftp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_log_syslog.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_nat.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_nat_ftp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nf_nat_tftp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nfnetlink.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nfnetlink_log.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/nfnetlink_queue.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/x_tables.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_CONNSECMARK.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_CT.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_MASQUERADE.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_NETMAP.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_REDIRECT.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_TCPMSS.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_TRACE.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_bpf.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_addrtype.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_comment.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_connlimit.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_connmark.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_conntrack.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_ecn.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_helper.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_hashlimit.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_hl.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_iprange.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_ipvs.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_l2tp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_length.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_limit.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_mac.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_mark.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_multiport.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_nat.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_owner.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_state.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_tcpmss.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/netfilter/xt_tcpudp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/xfrm/xfrm_algo.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/xfrm/xfrm_interface.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/xfrm/xfrm_ipcomp.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/net/xfrm/xfrm_user.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/sound/soc/codecs/snd-soc-spdif-rx.ko
INSTALL /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170/kernel/sound/soc/codecs/snd-soc-spdif-tx.ko
DEPMOD /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/install_pkg/linux-2c3e329b7dec94edae5e9fb5f33669239c384436/usr/lib/kernel-overlays/base/lib/modules/5.15.170
Making multidtb g12a_s905x2_beelink_gt_mini_a.dtb
DTB combiner:
Input directory: 'common_drivers/arch/arm64/boot/dts/amlogic/dtbtool_input/'
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/g12a_s905x2_beelink_gt_mini_a.dtb'
Found file: g12a_s905x2_beelink_gt_mini_a_4g.dtb
chipset: g12a, platform: s905x2, rev: 4g
Found file: g12a_s905x2_beelink_gt_mini_a_2g.dtb
chipset: g12a, platform: s905x2, rev: 2g
=> Found 2 unique DTB(s)
Generating master DTB... completed
Compressing master DTB... completed
Making multidtb g12a_s905x2_beelink_gt1_mini.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/g12a_s905x2_beelink_gt1_mini.dtb'
Found file: g12a_s905x2_beelink_gt1_mini_2g.dtb
chipset: g12a, platform: u212, rev: 2g
Found file: g12a_s905x2_beelink_gt1_mini_4g.dtb
chipset: g12a, platform: u212, rev: 4g
Making multidtb g12b_bananapi_m2s.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/g12b_bananapi_m2s.dtb'
Found file: g12b_s922x_bananapi_m2s.dtb
chipset: bananapi, platform: m2s, rev: 922x
Found file: g12b_a311d_bananapi_m2s.dtb
chipset: bananapi, platform: m2s, rev: a311d
Making multidtb g12b_s922x_beelink_gs_king_x.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/g12b_s922x_beelink_gs_king_x.dtb'
Found file: g12b_s922x_beelink_gs_king_x_rev_a.dtb
chipset: g12b, platform: w400, rev: a
Found file: g12b_s922x_beelink_gs_king_x.dtb
chipset: g12b, platform: w400, rev: b
Making multidtb g12b_s922x_beelink_gt_king.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/g12b_s922x_beelink_gt_king.dtb'
Found file: g12b_s922x_beelink_gt_king.dtb
Found file: g12b_s922x_beelink_gt_king_rev_a.dtb
Making multidtb g12b_s922x_odroid_n2.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/g12b_s922x_odroid_n2.dtb'
Found file: g12b_s922x_odroid_n2plus_rev_c.dtb
chipset: g12b, platform: w400, rev: c
Found file: g12b_s922x_odroid_n2.dtb
Found file: g12b_s922x_odroid_n2plus.dtb
=> Found 3 unique DTB(s)
Making multidtb g12b_s922x_ugoos_am6.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/g12b_s922x_ugoos_am6.dtb'
Found file: g12b_s922x_ugoos_am6_4g.dtb
chipset: g12b, platform: AM6, rev: b4g
Found file: g12b_s922x_ugoos_am6_rev_a_4g.dtb
chipset: g12b, platform: AM6, rev: a4g
Found file: g12b_s922x_ugoos_am6_2g.dtb
chipset: g12b, platform: AM6, rev: b2g
Found file: g12b_s922x_ugoos_am6_rev_a_2g.dtb
chipset: g12b, platform: AM6, rev: a2g
=> Found 4 unique DTB(s)
Making multidtb g12b_s922x_ugoos_am6b.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/g12b_s922x_ugoos_am6b.dtb'
Found file: g12b_s922x_ugoos_am6b_rev_a_2g.dtb
chipset: g12b, platform: AM6b, rev: a2g
Found file: g12b_s922x_ugoos_am6b_2g.dtb
chipset: g12b, platform: AM6b, rev: b2g
Found file: g12b_s922x_ugoos_am6b_4g.dtb
chipset: g12b, platform: AM6b, rev: b4g
Found file: g12b_s922x_ugoos_am6b_rev_a_4g.dtb
chipset: g12b, platform: AM6b, rev: a4g
Making multidtb s4_s905y4_buzztv_hd5.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/s4_s905y4_buzztv_hd5.dtb'
Found file: s4_s905y4_buzztv_hd5_2g.dtb
chipset: s4, platform: hd5, rev: 2g
Found file: s4_s905y4_buzztv_hd5_4g.dtb
chipset: s4, platform: hd5, rev: 4g
Making multidtb s5_s928x_ugoos_am8.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/s5_s928x_ugoos_am8.dtb'
Found file: s5_s928x_ugoos_am8_8g.dtb
chipset: s5, platform: s928x, rev: AM8-8g
Found file: s5_s928x_ugoos_am8_4g.dtb
chipset: s5, platform: s928x, rev: AM8-4g
Making multidtb s5_s928x_x96_x10.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/s5_s928x_x96_x10.dtb'
Found file: s5_s928x_x96_x10_8g.dtb
chipset: s5, platform: s928x, rev: ax201-v28g
Found file: s5_s928x_x96_x10_4g.dtb
Making multidtb sc2_s905x4_buzztv_x5.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/sc2_s905x4_buzztv_x5.dtb'
Found file: sc2_s905x4_buzztv_x5_2g.dtb
chipset: sc2, platform: s905x4, rev: ah212-Eth-2g
Found file: sc2_s905x4_buzztv_x5_2g_1gbit.dtb
chipset: sc2, platform: s905x4, rev: ah212-gEth-2g
Found file: sc2_s905x4_buzztv_x5_4g_1gbit.dtb
chipset: sc2, platform: s905x4, rev: ah212-gEth-4g
Found file: sc2_s905x4_buzztv_x5_4g.dtb
chipset: sc2, platform: s905x4, rev: ah212-Eth-4g
Making multidtb sc2_s905x4_sei_smb_280.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/sc2_s905x4_sei_smb_280.dtb'
Found file: sc2_s905x4_sei_smb_280_id6.dtb
chipset: sc2, platform: s905x4, rev: ah212-id6
Found file: sc2_s905x4_sei_smb_280_id5.dtb
chipset: sc2, platform: s905x4, rev: ah212-id5
Found file: sc2_s905x4_sei_smb_280_id7.dtb
chipset: sc2, platform: s905x4, rev: ah212-id7
Making multidtb sm1_s905x3_beelink_gt1mini2.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/sm1_s905x3_beelink_gt1mini2.dtb'
Found file: sm1_s905x3_beelink_gt1mini2_4g.dtb
chipset: sm1, platform: ac213, rev: 4g
Found file: sm1_s905x3_beelink_gt1mini2_2g.dtb
chipset: sm1, platform: ac213, rev: 2g
Making multidtb t7_a311d2_beelink_gt_king_ii.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/t7_a311d2_beelink_gt_king_ii.dtb'
Found file: t7_a311d2_beelink_gt_king_ii_4g.dtb
chipset: t7, platform: a311d2, rev: an400
Found file: t7_a311d2_beelink_gt_king_ii_8g.dtb
chipset: t7, platform: a311d2, rev: an400-8g
Making multidtb t7_a311d2_khadas_vim4.dtb
DTB combiner:
Output file: 'common_drivers/arch/arm64/boot/dts/amlogic/t7_a311d2_khadas_vim4.dtb'
Found file: t7_a311d2_khadas_vim4.dtb
Found file: t7c_a311d2_khadas_vim4n.dtb
chipset: t7c, platform: a311d2, rev: an400-8g
Compressing initramfs.cpio with zstd
10523136 bytes /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/image/initramfs.cpio
7274131 bytes /home/debian/CoreElec22/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/image/initramfs.cpio.zst
I then updated the device by copying the Image.lzo as previously suggested.
The new print message has not appeared in the dmesg output. However, the second line of the dmesg output that says the linux version has a new timestamp that reflects when I built it.
edit: I appears I altered the wrong copy of amdv.c as there are multiple of then in build folder. Modifying the correct one works. Any suggestion on how to make this work without directly modifying code in the build folder so git can be used? The patch files I’ve been using (as per How to develop for NO effectively without excessive build times? - #6 by vpeter) seem to generate a full rebuild
