Hi guys. I’m currently running 9.2.2 on Odriod N2. I would like to do a fresh install of 9.2.2 as there are some issues after installing embuary skin. I went back to the original estuary skin but doesn’t seem to work.
For example, after the N2 goes into screensaver dim, I can’t get out of screensaver by pressing any key on my Minix Neo A2 lite remote. I can see a message pop up(very dim as it’s still in screensaver mode) saying retrieving remote image list, but the progress circle is stuck and says 0%. Is a fresh install the best way to get everything running properly again? I would appreciate any help. Thank you.
