Thanks, but what I’m actually asking is what the unnamed (with .tar extension) nightly build is.
On the nightly download page, there are several builds clearly identified by platform, such as Generic, Odroid, Khadas, Radxa, etc. But there is also a nightly build shown simply as:
So I’m not asking what a .tar file is or how to use the .tar format. I’m asking which build/platform this particular nightly is for, and what it is intended for, since its name doesn’t identify it as Generic, Odroid, Khadas, Radxa, etc.
So, can I use this .tar nightly to roll back my current Generic installation to an older nightly?
I’m new to CoreELEC and couldn’t find a clear answer to this when searching, so I thought I’d ask here.
Once you have done the initial install with the .img for the correct platform, you can use the .tar for any of them to do the update. Just copy the .tar in the update folder through the SMB share and reboot.
