How to stop N2 going to sleep?
My N2 has the annoying habit of going to sleep overnight and the wake from sleep feature cannot then wake it again. The strange thing is the going off of the TV isn’t the trigger as it stays awake for a time after the TV is off. I have CEC disabled so this shouldn’t be an issue. I have scheduled tasks which happen overnight which this messes with so i want to stop it going to sleep and remain on all the time.
Can’t identify the setting to achieve this.
Never happened to me. What else could put it to sleep mode if not CEC?
RTC?
No RTC installed.
Remove HDMI cable and check if it sleeps so you can be sure that is not CEC
Will give it a try.
Just to close this out. With HDMI plugged in it always goes to sleep, with it unplugged it doesn’t. This confirms it is CEC related but none of the CEC functions stop it.
I had to edit the config.INI file and enable the CEC mask and set it to Zero. This stops the N2 from going to sleep.
