Can someone tell me what’s wrong with encoding of this video sample is 22min and 475 Mb
Software decoding works OK and with hardware decoding I get this:
It plays fine for me with hardware encoding. There are some brief artifacts at the beginning but from then on it’s all good.
On N2 ? Then it’s something amiss with my setup. This is the first video that my N2 doesn’t hardware decode since I bought it a year ago. And it’s a very simple video, would never expect it to have problems.
Edit: The sample I sent is different than the original video, I just tried it and it plays OK. I used Avidemux to cut 40sec sample and the saved part got “fixed” by this process.
Sorry that I didn’t check the resulted video snipet and sent a file that works OK. Replaced that sample with the original video
Don’t know how to cut a piece that will not be changed, except to send the whole file - 22 min and 475 Mb.
Here is the complete episode if anybody is willing to test and find out what is wrong with encoding: Sample1
