If a thread for this exists somewhere, please lock this and point me there. I did search .
Read at AVS forum that installing CE to internal flash/eMMC is not possible w/Android 14 on new boxes like AM9 Pro, SK4, etc. Namely dual boot, but that installing over the Android OS may be possible (but not recommended)? Just wanted to understand from CE devs if both are true, and why for latter? Thanks.
if you reformat internal partitions to be compatible it’s possible but not advisable, especially concerning regular users who can’t just use aml burn to recover
Been digging into eMMC-install options for the SK4 since ceemmc doesn’t support it, and wanted to cross-link two threads that don’t currently reference each other (this account can’t post links or @mentions yet, so by title/username plain text)
“Install to Internal (eMMC) on Ugoos AM9 Pro, SK4/Pro, etc.?” — closed/solved. Portisch confirmed it’s not possible with Android 14, userdata is encrypted, so ceemmc becomes obsolete. Correct for ceemmc’s dual-boot/shared-storage approach.
“CoreELEC eMMC installer for Ugoos AM9” (in Community Projects) — a separate, explicitly-unsupported community tool by forum user dangerouslaser (repo ugoos-am9-pro-coreelec-emmc on GitHub) that sidesteps the encrypted-userdata problem instead of solving it: deletes rsv+userdata outright and carves out CE_FLASH/CE_STORAGE in their place, no dual-boot, super and boot0/boot1 left untouched. README claims testing on physical SK4/SK4 Pro hardware, and its documented partition layout and coreelec-dt-id (s7d_s905x5m_ugoos_sk4) match my own SK4 exactly.
Since anyone reading only the first thread would come away thinking it’s flatly impossible, seemed worth mentioning here too.
One data point for dangerouslaser and anyone else with a unit to compare: the README’s safety argument rests on boot0/boot1 being unconditionally hardware write-protected. On my SK4 (22.0-Piers_nightly_20260810), reading EXT_CSD directly (bytes 173/174 via /sys/kernel/debug/mmc0/mmc0:0001/ext_csd) gives BOOT_WP=0x00, BOOT_WP_STATUS=0x00 — no eMMC-level boot-partition write protection currently active. Could be unit/batch variance, or a different protection layer I’m not accounting for — genuinely asking rather than asserting, since it bears on how strong that “can’t be bricked” guarantee actually is.
If you have installed CE to EMMC (unsupported) and need to do a firmware upgrade to run the latest nightlies, and don’t want to restore android to do so, there are instructions and tooling in my repo.
any support requests regarding this should be posted in my repo - not here.
