Is it possible to add information about the current speed of the internet connection to the Kodi / Coreelec menu: wired and wireless?
Only after some time I realized that the gigabit wired connection, after waking up from the suspend option, drops to:
Speed: 100Mb / s
I added an entry to /storage/.config/autorun.sh
ethtool -s eth0 speed 1000 duplex full autoneg off
and it’s OK … but it would be easier for others to diagnose the problem
You could try disabling Green Ethernet and similar power saving options on the other end (your router).
