Is it possible to add driver module of RTL8723?
WiFi of X96S TV Stick 4/32G version, which equipped with AP6255, works flawlessly for both 2.4 and 5GHz band. Bluetooth adapter works as well (at least it shows every BT device around). However, WiFi and BT of the X96S 2/16G version does not works. Instead of using the AP6255 WiFi/BT module, it came with RTL8723 which supports only the 2.4GHz band. Is it possible to include the driver module of that chip in Amlogic-ng build?
Thanks.
