Greetings,
LAN connection is required to use TVHeadend system.
Well, if you have to use the network connection in place, eg; in the village. How can I use it?
Just think this is crazy.
Best regards…
Greetings,
Best regards…
I got mine working without Lan. I had to disable Samba
Settings
=>Coreelec
=>Services
=>Disable Samba
I also went in via SSH and changed the following file:
storage/.kodi/addons/service.tvheadend42/system.d/service.tvheadend42.service
I commented out the following lines
#After=network-online.service
#Requires=network-online.service
Seemed to do the trick
Greetings,
You are super…
Thank you very much for your information and tips.
So it would be nice to put it as an option on the CoreELEC tab in the Settings menu to make it easier.
Best regards…
