Greetings,
Is there an Equalizer Plugin?
I can not find it.
Because the reverb effect is very high in songs and music clips.
Which makes me very uncomfortable.
Best regards…
Greetings,
I can not find it.
Best regards…
'fraid not (AudioDSP).
However, there is pulseeffects, which with some persuasion could run headless.
I am looking for something as well, since my bass is a bit weak.
You can’t use pulseefect with Coreelec. But there is some good news about dsp: https://github.com/AchimTuran/xbmc/projects/1
So it’s being worked on again.
Interesting this, i have the opposite problem as my bass is way over the top, soundbar is currently on -7 lol.
It only has preset sound settings so an equalizer to adjust frequencies would be amazing.
