I have Mecool K3 Pro box. Everything was working fine last couple of weeks but recently the DVB-S stream over TVH started to stutter. Any idea how to fix it please? Thank you
And if you would take the time to search the forum, you’ll find about 50 more posts relating to this topic.
Are you using tvheadend 4.3? If yes then switch to tvheadend 4.2.
I can’t recommend tvh 4.3, in the past I always had streaming problems, tvh 4.2 always works fine.
NOTE.- This comment is very old, I have been using docker linuxserver / tvheadend 4.3 for months, it is updated very often and it works very well (14/08/2021).
Can I install 4.2 over 4.3?
