Zodler
23 February 2019 19:28
1
I have minix neo u9-h. I added this to the file in rc_keymaps
0x112 KEY_CONFIG
This doesn’t work. The 0x112 command is working, if I add something else like KEY_MENU, it works.
The problem is with KEY_CONFIG, it seems CoreELEC 9 does not execute it.
Even when I add the Keymap Editor addon, it does not register under it. Any ideas? Could you please try KEY_CONFIG under CoreELEC 9?
I’ve noticed this myself, it’s on my list of things to look at.
Zodler
24 February 2019 10:57
3
Thank you. Please look closer. It is not just KEY_CONFIG. It’s many more. For example KEY_I also doesn’t register.
If you have many more examples then please post them.
Zodler
24 February 2019 22:25
5
I only tested these 2 but probably it’s the same one bug that is causing this. Probably when one is corrected, the rest should work too.
No that is not how it works, some key functions have changed ie KEY_HOME is now KEY_HOMEPAGE, some of these we automatically remap at boot time so the user does not have to reconfigure their config.
We are more than happy to try and help you but please do not make false statements in the future.
Zodler
27 February 2019 23:24
7
I have made no false statements at all. In fact, I have made no statements at all. You please learn to be respectful in the future. Good day.
relkai
27 February 2019 23:46
8
I think Adam was referring to this “it’s many more”, when you only tested and confirmed two.
Anyway, let’s try to calm down a bit and solve this damn problem.
If you know about more buttons not working properly, please post them here.
Because every key needs to be mapped manually, it can only be fixed with a complete set of non-working keys.
Exactly @relkai
If your going to say something is broken or doesn’t work then at least test it first instead of wasting our time.
I just installed CoreELEC 9.0.2.
KEY_CONFIG still not registering. Any progress on this?
I have tried both methods with
1- remote.conf
or
2- rc_maps.cfg + corresponding u9.txt
Both give the same results.
It was removed in Leia by the Kodi team here .
18 June 2019 12:41
12
KEY_FAV never seems to register even when using Keymap editor.
Thanks for the link. Where I have to look at? Is it LinuxInputDevices.cpp? When I look inside it, it still has
KEY_CONFIG at line 270.
* Portions copied from DirectFB:
* Copyright (C) 2001-2009 The world wide DirectFB Open Source Community (directfb.org)
* Copyright (C) 2000-2004 Convergence (integrated media) GmbH
* All rights reserved.
* Written by Denis Oliver Kropp <dok@directfb.org>,
* Andreas Hundt <andi@fischlustig.de>,
* Sven Neumann <neo@directfb.org>,
* Ville Syrjälä <syrjala@sci.fi> and
* Claudio Ciccani <klan@users.sf.net>.
* Copyright (C) 2005-2013 Team XBMC
* http://kodi.tv
* This Program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2, or (at your option)
* any later version.
* This Program is distributed in the hope that it will be useful,
This file has been truncated. show original
Does KEY_PLAY work for you? That also doesn’t work.
18 June 2019 14:40
15
KEY_PLAY play works for me.
The “SAT” key doesn’t accept any function.
I always believed that this was something to do with LIRC grabbing certain key presses and not passing them on.
I can read all the commands that my remotes send when I type these with ssh
systemctl stop kodi
systemctl stop eventlircd
ir-keytable -p nec -t
The problem for me is with the linux constants that are not all read like KEY_PLAY and KEY_CONFIG.
For the workaround I’m going to use KEY_1, KEY_2 …
Like you I use the Keymap Editor Addon to test if they register or not.
18 June 2019 21:53
17
I used to do the same, but gave up as the constant round of upgrades kept breaking things. i have just enough functionality to get by. I could never get the KEY_FAV to work whatever I did which is kind of annoying.
bam
23 October 2019 16:03
18
It’s XKB who doesn’t pass KEY_FAV by default.
If you need more details, I’ll provide.
bam
23 October 2019 16:13
19
Here is the correct link. You can rise an issue in Kodi tracker. It bugs me too.
{ XKB_KEY_Undo, XBMCK_UNDO },
{ XKB_KEY_XF86Sleep, XBMCK_SLEEP },
// Unmapped: XBMCK_GUIDE, XBMCK_SETTINGS, XBMCK_INFO
{ XKB_KEY_XF86Red, XBMCK_RED },
{ XKB_KEY_XF86Green, XBMCK_GREEN },
{ XKB_KEY_XF86Yellow, XBMCK_YELLOW },
{ XKB_KEY_XF86Blue, XBMCK_BLUE },
// Unmapped: XBMCK_ZOOM, XBMCK_TEXT
{ XKB_KEY_XF86Favorites, XBMCK_FAVORITES },
{ XKB_KEY_XF86HomePage, XBMCK_HOMEPAGE },
// Unmapped: XBMCK_CONFIG, XBMCK_EPG
// Media keys
{ XKB_KEY_XF86Eject, XBMCK_EJECT },
{ XKB_KEY_Cancel, XBMCK_STOP },
{ XKB_KEY_XF86AudioRecord, XBMCK_RECORD },
// XBMCK_REWIND clashes with XBMCK_MEDIA_REWIND
{ XKB_KEY_XF86Phone, XBMCK_PHONE },
{ XKB_KEY_XF86AudioPlay, XBMCK_PLAY },
{ XKB_KEY_XF86AudioRandomPlay, XBMCK_SHUFFLE }
// XBMCK_FASTFORWARD clashes with XBMCK_MEDIA_FASTFORWARD
