It does look competitively priced and when speeds tests against S905X2/3 and S912 are available it should show a clearer path.
The VIM3L should be 20-25% faster than older S905** SOCs in TV boxes.
Who know 40 pin gpio pinout? Support vtv board
Very nice decision for us, who not caring about CPU power, just wanting
-low heat
-low power consuption
-x264/x265 HW acc
devices!
By the quick look only thing missing is passive heatsing (wondering how much is needed, when I see it in full package)ā¦ I welcome GPIO for hyphotetical possibility connect IR TSOPā¦ Price is good.
What SKU will be delivered for this pre-order? KON or NON? And in the SD Mode we can use SDR104? (for using Coreelec from the sd card)
I think Mainline claims are a result of overselling by Bables50 who is the main AML developer over at LE. Still a way off anything usable for the average JO.
Ok I am sold I preordered some. Not need right now, but maybe after few years HDR would mean something to me. Crossfingers to the project.
Same with me, just pulled the trigger on a VIM3L. I have a Odroid-N2 already, very happy with it. Just want to test the VIM3L in a second room for fun
They are sending them now. I am very curious about target āshippingā price (customs, etc.)ā¦
Will wait patiently for CE stable for this one. And also, when those hits my infrastructure, I would need bump all my C2 9.0.3ās (rock solid) to whole new branch 4.9 (which scares me a bit), just because I am not sure if Kodi 18.3 / 18.4 are compatible on DB level. I heard something about new bugs in 18.4, so that also haunting me a littleā¦
One note:
For recovery mode (ie. booting from USB/SD) you must use keys method, after you flash Khadas Android Pie. .apk method for booting to recovery mode doesnt work here.
Booting from USB/SD doesnt work with stock CE on eMMC, you will get "boot= corrupted" message.
Reboot to Other OS option power menu added by SuperCeleron Android Pie ATV latest.
which works.(Debug Version)
Are there any news around non-nightly builds for the VIM3L device?
NOTICE: Khadas VIM3L Users
If you have a Khadas VIM3L then please do not update your device with this update, a separate update will be made available as S905D3 is not supported in this update.
This notice is staying there foreverā¦
Thanks!
The next stable release will be usable on VIM3L.
I flashed the stabled version to a sd, but it wonĀ“t bootā¦
I press power button and then reset shortly and wait 10 second power button pressed, nothing happensā¦Ā“~
The generic image is what i flashed and put ont ht root the right device treeā¦ What i am doing wrong?
ItĀ“s possible to boot from android for SD ?
I used this some time ago https://play.google.com/store/apps/details?id=jackpal.androidterm
then type reboot update
Thank you . Which version you use of Coreelect ? On the devices tree only shows a311.dtb file, doesnĀ“t show the vim 3 L ā¦
For vim3L you have to go with nightlies
But there is an advertising saying nightly wonĀ“t work
Where? Thereās a warning in the stable 9.2.1 that says it wonāt work on VIM3L. If you download latest nightly youāll see VIM3L in device_trees.
