Kinhank K9 - SoC S5 S928X-K
[Please point me in the right direction if this is not the correct place to post]
A DV video that plays properly on the NE (21.3 Stable) version gives a blank screen (audio fine) on NO nightly using the added dovi.ko file.
MediaInfo tells me the stream is “Profile 5, dvhe.05.06, BL+RPU, no metadata compression”. Is this just a ‘tough you’re on an unsupported box’ thing or is is something I can work around?
I’ve followed the guide to get the BT controller working. For the record this is the output:
I: Bus=0005 Vendor=000d Product=3838 Version=000d
N: Name=“XiaoPaiRC_173S Consumer Control”
P: Phys=44:f5:3e:83:f9:95
S: Sysfs=/devices/virtual/misc/uhid/0005:000D:3838.0001/input/input7
U: Uniq=28:31:7e:b4:2f:38
H: Handlers=kbd event6
B: PROP=0
B: EV=1b
B: KEY=30640 0 0 808003072fd025 bf84444200000000 1 13007300138000 43fa00404c00 9e168000004400 10000002
B: ABS=100000000
B: MSC=10
N: Name=“XiaoPaiRC_173S Mouse”
S: Sysfs=/devices/virtual/misc/uhid/0005:000D:3838.0001/input/input8
H: Handlers=mouse0 event7
B: PROP=0
B: EV=17
B: KEY=70000 0 0 0 0
B: REL=903
B: MSC=10
N: Name=“XiaoPaiRC_173S Keypad”
S: Sysfs=/devices/virtual/misc/uhid/0005:000D:3838.0001/input/input9
H: Handlers=sysrq kbd leds event8
B: PROP=0
B: EV=120013
B: KEY=1000000000007 ff9f207ac14057ff febeffdfffefffff fffffffffffffffe
B: MSC=10
B: LED=1f
I’ve executed evtest on all three events but none respond to a key touch. So a little bit stumped!!
Try again tomorrow
Of the three - this looks the most likely:
Input device ID: bus 0x5 vendor 0xd product 0x3838 version 0xd
Input device name: “XiaoPaiRC_173S Consumer Control”
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 1 (KEY_ESC)
Event code 28 (KEY_ENTER)
Event code 74 (KEY_KPMINUS)
Event code 78 (KEY_KPPLUS)
Event code 103 (KEY_UP)
Event code 105 (KEY_LEFT)
Event code 106 (KEY_RIGHT)
Event code 108 (KEY_DOWN)
Event code 113 (KEY_MUTE)
Event code 114 (KEY_VOLUMEDOWN)
Event code 115 (KEY_VOLUMEUP)
Event code 116 (KEY_POWER)
Event code 119 (KEY_PAUSE)
Event code 138 (KEY_HELP)
Event code 139 (KEY_MENU)
Event code 142 (KEY_SLEEP)
Event code 150 (KEY_WWW)
Event code 161 (KEY_EJECTCD)
Event code 163 (KEY_NEXTSONG)
Event code 164 (KEY_PLAYPAUSE)
Event code 165 (KEY_PREVIOUSSONG)
Event code 166 (KEY_STOPCD)
Event code 167 (KEY_RECORD)
Event code 168 (KEY_REWIND)
Event code 169 (KEY_PHONE)
Event code 174 (KEY_EXIT)
Event code 207 (KEY_PLAY)
Event code 208 (KEY_FASTFORWARD)
Event code 209 (KEY_BASSBOOST)
Event code 212 (KEY_CAMERA)
Event code 224 (KEY_BRIGHTNESSDOWN)
Event code 225 (KEY_BRIGHTNESSUP)
Event code 228 (KEY_KBDILLUMTOGGLE)
Event code 229 (KEY_KBDILLUMDOWN)
Event code 230 (KEY_KBDILLUMUP)
Event code 240 (KEY_UNKNOWN)
Event code 241 (KEY_VIDEO_NEXT)
Event code 244 (KEY_BRIGHTNESS_ZERO)
Event code 256 (BTN_0)
Event code 353 (KEY_SELECT)
Event code 358 (KEY_INFO)
Event code 362 (KEY_PROGRAM)
Event code 366 (KEY_PVR)
Event code 370 (KEY_SUBTITLE)
Event code 375 (KEY_SCREEN)
Event code 376 (KEY_PC)
Event code 377 (KEY_TV)
Event code 378 (KEY_TV2)
Event code 379 (KEY_VCR)
Event code 380 (KEY_VCR2)
Event code 381 (KEY_SAT)
Event code 383 (KEY_CD)
Event code 384 (KEY_TAPE)
Event code 386 (KEY_TUNER)
Event code 389 (KEY_DVD)
Event code 396 (KEY_MEMO)
Event code 398 (KEY_RED)
Event code 399 (KEY_GREEN)
Event code 400 (KEY_YELLOW)
Event code 401 (KEY_BLUE)
Event code 402 (KEY_CHANNELUP)
Event code 403 (KEY_CHANNELDOWN)
Event code 405 (KEY_LAST)
Event code 408 (KEY_RESTART)
Event code 409 (KEY_SLOW)
Event code 410 (KEY_SHUFFLE)
Event code 416 (KEY_VIDEOPHONE)
Event code 417 (KEY_GAMES)
Event code 431 (KEY_DISPLAYTOGGLE)
Event code 439 (KEY_MEDIA_REPEAT)
Event code 582 (KEY_VOICECOMMAND)
Event code 585 (?)
Event code 586 (?)
Event code 592 (KEY_BRIGHTNESS_MIN)
Event code 593 (KEY_BRIGHTNESS_MAX)
Event type 3 (EV_ABS)
Event code 32 (ABS_VOLUME)
Value      0
Min        0
Max      255
Event type 4 (EV_MSC)
Event code 4 (MSC_SCAN)
I’ve used the IR code finder guide to track all the keys on the remote and then discovered it was identical to the one for the Tencent! I put that file in the root of the usb and it worked for a few keypresses then the box locked up as if the key press was stuck. On reboot it has reverted to not working. I then realised it need to be manually shifted to the correct directory (/storage/.config). Did that and rebooted and all good.
So either put the remote.conf file on the usb right at the start and it will be moved as part of first install or add later manually
So back to the BT!
