Since updating to 8.90.5 we are finding an issue in that Kodi is freezing when switching channels using TVHeadend backend (running on a seperate machine).
Normally before the odd freeze I would SSH onto the box and do a systemctl stop kodi followed by systemctl start kodi and this would be fine, but I am finding that doesn’t achieve anything. Issuing a reboot just makes the box stick as well meaning that the unit has to be power cycled to get into a working order.
I enabled debug logging within Kodi and have attached some logs, hopefully this will be an indicator of what is happening and hopefully someone can help?
I can confirm exactly the same problem using TVH backend on a remote server.
Nearly everytime I’m switching to another channel, the box (Wetek Hub) freezes and needs to be power cycled.
If I stop the current channel before starting another one, it is working fine.
I’m experiencing this issue since 8.95.0.
In 8.90.5 TVH was still working without any problems.
