Hi - after my last update the system starts up with the HardKernel logo then the CoreELEC logo then a whole bunch of lines of code then the process repeats continuously. I updated from within coreelec so I’m not sure what happened. Any help appreciated
If you have USB HDD connected then disconnect or reconnect it to another side USB.
Also this issue is fixed in nightly builds
Thank you - that worked I thought I have to reinstall and start over…
