Maybe I need to hardcode this and the 4k gui settings ![]()
Good to know it’s working now for someone else.
Yes!!
Please do
More user friendly the better
I dont remember having to do that in your
5.15.119 kernel build.
Just 4K gui and reboot
Unless was set as defaults?
Yeah, it was hardcoded as the default.
Didn’t matter what was set in the giu as that functionality was broken original 5.15 kernel build.
In this picture link in the top left corner under GENERAL, bottom line: HDMI mode: HDMI, HDR Type: SDR It should be Dolby Vision instead of SDR…
I tested with at least 10 different Dolby Vision content.
Is this an LG OLED (CX) FW bug or real info?
latest CE21 nightly
LG OLED CX latest firmware
calibrated Dolby Vision Cinema mode (Calman)
This build us for amlogic SoC Without Dolby Vision compatible/certification.
If you are using Am6b Am6plus there is no dovi.ko in kernel.
And is not required with Doppingkoala Build!!
Please test on other amlogic s905x4, s905x, s905x3, etc
Currently testing on Tanix Tx5 Plus Deluxe S905X3
So it turns processing the metadata ahead of time is enough to make a -no build work properly.
File on MEGA
Pretty much the same as the previous -ng build in Learning about Dolby Vision and CoreELEC development - #341 by doppingkoala. Differences are:
echo 3000 > /sys/module/amvideo/parameters/osd_L5_timeout_ms
You’re doing fantastic job man! Thank you! ![]()
Will this build work on the X96Air (S905X3)?
should work on anything that runs coreelec
Thanks. I did a new install (20.5 Nexus ng) and updated with the version from post #349. Turns out that DV works with my X96Air …
Played a few files and found that profile 8 looks perfect, but with profile 5, the colors are off. Not sure how to fix that … Also, for some reason, I can’t ssh into this build. My putty window just disappears after I enter my login/password. I do have SSH turned on.
That is known. It is a result of this work only playing with metadata, but profile 5 content also requires the actual video signal to be modified (polynomial reshaping) which hasn’t been looked at. I have no idea how that could be done on these devices.
That said, it is possible on these unlicensed amlogic boxes as *SMC (the related project that’s acronym apparently cannot even be included in a post…) does it as a part of playing back profile 5 content as HDR10/SDR. Unfortunately, no details as to how they did this could be shared, apparently it is subject to a NDA.
This is my best guess
May eventually look at this given that p8, p7 MEL, p7 FEL as MEL playback seems to work without any issues now.
@Portisch (or anyone else that knows CE well) Any suggestions on how polynomial reshaping could be performed?
I’ve done nothing to do with ssh for this build and others have had no issues.
Might be an issue with known_hosts on your computer not matching after you updated - I’ve had this happen. Try deleting the relevant entry in your known_hosts file.
Never mind the ssh problem. I think my sd card must have been corrupted. I re-install everything from scratch and the ssh problem went away. Also, now I can reboot normally whereas before I had to reboot via the “Reboot to Coreelec” app from android …
Is this a typo ?
Thought new build was back to the New Order
5.15.119 kernel?
Have not tested yet
New build from Doppingkoala
No, that wasn’t a typo. I wasn’t sure whether the -no build would be compatible with my X96Air, so I chose the 20.5 Nexus ng build along with the update in post #339 (not #349 as stated in my original post; that was a typo). Sorry for the confusion.
All is good
Nice to see others testing Doppingkoala Builds
I would encourage others to test as well!!!
Hi @doppingkoala unfortunately it is crashing on my GSKX.
https://paste.coreelec.org/BankruptPerjury
https://paste.coreelec.org/AndrewsHopeful
dmesg | paste
https://paste.coreelec.org/RunwayMaxine
Doesn’t look like you did
Check the settings.
If you still have problems, post a photo of the settings page so I can confirm they are correct, then we can move on to looking at what else is the problem.
20.5 build is very good, i have dolby vision + atmos passthrough working, tv is lg c1, box is x96 air, 905x3
but video will stutter when subtitle is shown when in dv mode, in non-dv mode it’s all good.
the blank screen when pausing, stuttering when gui showing doesnt bother m that much, but stutters during subtitle is a dealbreaker.
let me test 22 build now
This generally or for a particular file? I’m not seeing issues with subtitles for a few files I tested.
How did that go? There is a slight difference in the implementations that may be relevant here.
Minor update from the -ng version in Learning about Dolby Vision and CoreELEC development - #341 by doppingkoala. See that post for setup + known issues.
Change:
Added automatic adjustment of L1 metadata. The value of the L1 min_pq is clipped to be at least the value of source_min_pq. The value of the L1 max_pq is clipped to be at most the value of source_max_pq. This matches what was observed in the hdmi tunnel captures.
Can disable this with
echo N > /sys/module/amvideo/parameters/L1_adjust
Re-enable with
echo Y > /sys/module/amvideo/parameters/L1_adjust
These can be changed while playing a file and have immediate affect.
With this change, the only differences between the DV output of this build and an official device I’m aware of are:
Offset positive Lift Test folder for examples.dovi.ko that unnecessarily do a color space conversion.For anyone that tests, please report any other differences in the displayed images output from this build and an official DV device for any content that is playable as p8.1.
