Learning about Dolby Vision and CoreELEC development
Figured that, but I more meant how to decode that to get the list of supported modes. Assuming that you used EDID Decode to get those snippets. That gives me
  Vendor-Specific Video Data Block (Dolby), OUI 00-D0-46:
    Version: 2 (12 bytes)
    DM Version: 4.x
    Backlt Min Luma: 100 cd/m^2
    Interface: Standard + Low-Latency
    Supports 10b 12b 444: Not supported
    Target Min PQ v2: 80 (0.00837904 cd/m^2)
    Target Max PQ v2: 3095 (1082 cd/m^2)
    Unique Rx, Ry: 0.67968750, 0.32031250
    Unique Gx, Gy: 0.26562500, 0.69140625
    Unique Bx, By: 0.14843750, 0.05859375
which doesn’t indicate that my tv support tv-led DV using a 12-bit YUV422 format - but it clearly does.
I have no idea…
After some digging it looks like the code is fine. Problem appears to be the tv is not correctly filling out the reported edid…
Still an interesting question as to how many other tv’s support the mode, whether they report to or not…
Given the number of problems that people have seen with edid’s, the best way to determine what a tv supports may be trial and error…
Brilliant work as always thanks for your dedication, will test later and report back.
Out of curiosity is uplifting with 21 difficult or that will be later after the final result?
Changes are now fairly isolated, should be fairly easy to change between any version. That is why I can do both the -ng and -no versions without much issue.
Only really using 20.5 because that is what I first started with. Anything specifically in the 21 version that is work updating for? All I’ve really seen is better FEL support which doesn’t apply here
Is mainly addons & plugins like inputstream and such, is all updated in 21. It’s not massively important so it can wait as the main thing is easier for you.
Thanks.
This is a 20.5 Nexus version. Do you plan to make also an 21.5 Omega version?
I think there’s time, were only on 21.1 Omega, four more until 21.5 :laughing:
Guess I’m not planning to make a 21.5 version then :rofl:
@Sholander @xmlcom Didn’t realise people were giving this enough use to care about the version… I’ll update to the latest -ng version next time I play with the code
OK, will wait then. It breathes new life energy to my old, but still very able, Odroid N2.
Oh my, got all my numbers confused :blush:
Why are you surprised? You just broke the first and fundamental law of DV physics, which until your work was: “To reproduce DV material, all devices in the reproduction chain, S0C/Box, transmission and display, must be DV certified”.
Now my N2, which does not have any DV certificates, properly reproduces DV material. :joy:
Probably caused by the change to a 12-bit YUV 422 tunnel mode. I’ll revert that with the next build.
That is expected. This build won’t cause the menu options from CE to show up and I haven’t added any.
Try confirming / redoing the settings required for the older builds and reboot?
Then it is a profile 5 file. These don’t play correctly.
CoreELEC doesn’t passthrough audio by default, you will need to re-enable audio passthrough.
I thought I have been able to play them from within Kodi, but it was from the LG internal player then. Too much tinkering too fast for my brain I guess.
I’ve set it already, but no luck. DTS:X plays well, TrueHD plays fine, only Atmos does not trigger my receiver anymore, but it doesn’t have anything to do with your build I think.
Thank you for your input.
fyi @Sholander @xmlcom and anyone else interested in an update to the CoreELEC version to 21.
Likely not going to happen anytime soon, CE-21 cannot build libdovi from source as is required and I don’t know how to create a patch that would allow that to happen.
Also not going to be any further updates to the -no version until the deal-breaking problems I am seeing in the nighties get resolved.
Ah…, sorry to hear that. Too bad for me, since I need CE-21 for some addons I use… Will need to see how can I get around with your Nexus version
Maybe this post from @cpm can be of some help
Despite what was stated by the devs, the problem is the outdated rust version that causes errors that prevent anything compiling.
I have tested this by reverting back to the original 21.1-Omega tag, which to my understanding is well before libdovi was removed. Re-adding libdovi is working for cpm because using the existing libdovi doesn’t involve compiling it. I needed to compile it because I have made some required modification.
The problematic commands are
 DEVICE=Amlogic-ng ./scripts/clean libdovi
 DEVICE=Amlogic-ng BUILD_FROM_SRC=yes ./scripts/build libdovi
with the second one resulting in error about the rust version. This was also a problem in CE-20.5, but thanks to @vpeter a patch was provided that updated fixed the issue.
Based on the file name, and other comments by the CE team, I assume that this patch isn’t applicable for CE-21 - may be wrong here. In any case, I’m do not intend to spend the time myself to try and figure out how to make such a patch - it will surely soon become outdated and broken anyway.
The best approach long term is really to just not use libdovi and just parse the original DV sei bitstream directly in c code. Actually a straightforward task - does not involve rewriting libdovi in c - just a small part. Not something on my immediate to-do list, have other things I would like to look at.
Maybe someone else would be interested in doing parsing in c code? If so, I can say exactly what would be required - essentially just need to extract this struct and any listed metadata blocks.
@Sholander If you can get the two above commands to successfully run on any commit from the coreelec-21 branch, I would move the CE-21 without without much issue.
That or someone write c code that parse the DV sei data the same as libdovi does - that way this problem could never reoccur and would also mean that no modifications to the kodi repo are required either.
