I’m ok with no BT as long as wifi works. Is that possible?
And I think I got cheated by the vendor. When I last purchased my s905x3 box from this aliexpress seller the wifi and wake on lan both worked. I asked for the exact same one but the wifi doesnt work and there is no wake on lan section at all!
I have a box that is looks similiar to the HK1 (S905X4) and always had issues with the built-in wifi.
I can connect to my routers 2,4Ghz but not to the 5Ghz although it is detected.
And even when connected to the 2,4Ghz I get a maximum of 2-11Mbit/s which is not enough to stream anything without buffering. Thats why I have to use an usb adapter.
I am using the latest ne nightly but ng had the same issue
I was reading this forum. I have x96 max+ device and hw device info shows that I have hit the ‘jackpot’ with JL2XX1 and W1-AML WiFi. ethernet is fine. I can give you remote SSH to this device if it would help you?
i’m writing here as i have issue to have BT issues with my N2+, using the official hardkernel 5BK dongle.
BT service is enable and i can see “HarmonyHub” in the list of bluetooth devices, but when trying to connect to it i have message “operation currently not permitted” or sometimes “didn’t receive a reply”
I’m using CE 19.5 stable, N2+, boot on emmc, ethernet plugged
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. USB3.1 Hub
Bus 001 Device 003: ID 0bda:c820 Realtek Semiconductor Corp. 802.11ac NIC
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
systemctl status bluetooth
[ 3.478043@4]- Bluetooth: Core ver 2.22
[ 3.478139@4]- Bluetooth: HCI device and connection manager initialized
[ 3.478148@4]- Bluetooth: HCI socket layer initialized
[ 3.478153@4]- Bluetooth: L2CAP socket layer initialized
[ 3.478167@4]- Bluetooth: SCO socket layer initialized
[ 3.545625@2]- Bluetooth: hci0: rtl: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[ 3.545632@2]- Bluetooth: hci0: rtl: loading rtl_bt/rtl8821c_config.bin
[ 3.559493@1]- Bluetooth: hci0: rtl: loading rtl_bt/rtl8821c_fw.bin
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2022-12-31 09:48:13 HKT; 4min 3s ago
Main PID: 3393 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 3686)
Memory: 2.9M
CGroup: /system.slice/bluetooth.service
└─3393 /usr/lib/bluetooth/bluetoothd
Dec 31 09:48:13 CoreELEC systemd[1]: Starting Bluetooth service...
Dec 31 09:48:13 CoreELEC bluetoothd[3393]: Bluetooth daemon 5.56
Dec 31 09:48:13 CoreELEC systemd[1]: Started Bluetooth service.
Dec 31 09:48:13 CoreELEC bluetoothd[3393]: Starting SDP server
Dec 31 09:48:13 CoreELEC bluetoothd[3393]: profiles/network/bnep.c:bnep_init() kernel lacks bnep-protocol support
Dec 31 09:48:13 CoreELEC bluetoothd[3393]: src/plugin.c:plugin_init() System does not support network plugin
Dec 31 09:48:13 CoreELEC bluetoothd[3393]: Bluetooth management interface 1.14 initialized
Dec 31 09:48:13 CoreELEC bluetoothd[3393]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Unknown Command (0x01)
Dec 31 09:48:13 CoreELEC bluetoothd[3393]: Endpoint registered: sender=:1.1 path=/MediaEndpoint/A2DPSink/sbc
Dec 31 09:48:13 CoreELEC bluetoothd[3393]: Endpoint registered: sender=:1.1 path=/MediaEndpoint/A2DPSource/sbc
Since I didn’t get any answer, I started looking for solutions on my own. I’ve come up with one that probably isn’t the best, but at least it works. I have included in autostart.sh the line: systemctl restart connman
Now the same networks appear as before, but with Wlan0. In these, the association does occur and it assigns me an ip, with the Wlan1 it was impossible for the association to take place.
It looks same issue I have seen with w1-aml driver. It try to create wlan0 interface but before wlan1 interface is created it want already to start open wlan0. But this is not possible while wlan1 is created.
You have also LAN connected and you might want to share your device for debugging?
Can you also please provide a dmesg | paste with Amlogic-ng CE-20?
