Hi all
I have a problem with custom ir codes in meson-ir. I created the file t95z under rc_keymaps and add the entry in rc_maps.cfg that is:
meson-ir * t95z
When I boot the box remote does not work, but if I launch this manually:
ir-keytable -a /storage/.config/rc_maps.cfg -s rc0
systemctl start eventlircd
systemctl start kodi
It works!
The problem happen on a S905x box upgrade to -ng, where in non ng version worked and in ng does not, and on a fresh installation of S905X3
