Hi All,
I would like to know how do i go about from an ODRIOD-C2 v9.2.7 to an ODRIOD-N2+ v19.1 to move my library and settings
Can i just do an backup from the settings and and restore or what is best.
Hi All,
Safest approach would be to have a full backup from CE 9.2, and a clean install of CE 19 on Odroid N2. After that you could restore the backup, but depends how your add-ons were ported from python 2 (CE 9.2) to python 3 (CE 19.xx).
Some of the stuff could be restored easily some of the add-ons may need to be installed / rebuild as new.
I used “Create System and Kodi Backup” from Backup in Coreelec tab. Yes, the built-in option. And I performed restore backup from there also. Some add-ons will be inactivated if their maintainer didn’t made the step to python 3.
Thanks alot let me go give this a try later today
