Minix U22-XJ Max kodi help
Hi all,
I have a MINIX U22-XJ Max running Kodi 21.2, and I’d like to know whether the new Kodi 22 version will support full Dolby Vision FEL playback on this device with Kodi 22 as i know version 21.2 can, or whether that support is only available in older versions of Kodi. and if it runs ok on older boxes
The reason I’m asking is that I’m interested in trying the new Arctic Fuse 3 skin, but I want to make sure I choose the right version of Kodi without losing full Dolby Vision FEL support.
Thanks in advance for any help or advice!
if you are talking about CE-22 (which is CE-NO 22), yes you have still dv fel om CE-NO 22.
running kodi on android doesn’t give you dv fel
sorry yes, i bypass android it boots straight into kodi as i installed without andriod using a MINIX U22-XJ Max
you are confusing me…are booting into CE? which version of CE ?
yes it boots straight into CE and version 21.2 i think
I don’t know why you had to ask the question. If you’ve managed to install CE to emmc, I’d have thought you’d know how to set up CoreELEC NO on an SD card and leave your emmc install alone until you’ve answered all your questions and proven that it’s for you.
@sonofdibnah
well if you read my first post i did not ask how to install it, i asked if kodi 22 still supported Dolby Vison FEL and if it ran ok on these older boxes. can you not ask simple questions on here.
so no need for the attitude
If you bothered to read you would know Fel is supported.
