Hi Folks,
i seem to be missing some resolutions in my whitelist. it was working at some point in the past and i suspect the problem may have occurred after updating to 9.2.2 (i am currently on 9.2.3 and issue still apparent)
i have my res set at 1920x1980i 59hz (the highest my TV will take) i used to have this set as only res in the whitelist to stop it changing often when switching channels using kodi pvr. Recently i see the refresh change often on swapping channels. i went to my whitelist and found all of the 1920x1080 are missing, even though i have the res set to 1080i right now, i also noticed that the res showing does not note the refresh rate, i am sure i used to have option in whitelist to select a res including refresh rate. I tried rebooting coreelec and TV lots of times but i just cannot get any 1080i to appear in my whitelist. see below from Kodi start for available res from my TV - i am missing something here? how to i get all the resolutions below to show as options in my whitelist?
2020-07-13 12:42:14.019 T:4089077776 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2020-07-13 12:42:14.019 T:4089077776 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2020-07-13 12:42:14.019 T:4089077776 NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2020-07-13 12:42:14.019 T:4089077776 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2020-07-13 12:42:14.019 T:4089077776 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2020-07-13 12:42:14.019 T:4089077776 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 60.000000 Hz
2020-07-13 12:42:14.019 T:4089077776 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 59.940060 Hz
2020-07-13 12:42:14.020 T:4089077776 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2020-07-13 12:42:14.020 T:4089077776 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 50.000000 Hz
Thanks!!
