I use coreelec 19.5-Matrix_rc2, my device is an amlogic s905w, everything works fine but since I have no RAM to spare I want to have a swapfile as a backup. basically followed the instructions here:
in my setup I boot from usb, and mount /dev/data (emmc) to /storage/mnt, when I reboot dmesg tells me that [ 6.065396@1]- systemd[1]: Starting Mounting swapfile... [ 7.663247@0]- systemd[1]: swap.service: Control process exited, code=exited, status=1/FAILURE [ 7.664586@0]- systemd[1]: swap.service: Failed with result 'exit-code'. [ 7.667067@0]- systemd[1]: Failed to start Mounting swapfile.
which is understandable because it’s probably mounting the partition AFTER the OS tries to mount the swapfile so it doesn’t exist.
is there a way I can mount emmc then mount swap so it can work?
