Hello, i have proved to use two remote files and it not work.
I use remote.conf and remote1.conf, but coreelec only work with remote1.com ever.
I must activate something?
SSH to device and run remoteinfo
and paste the link.
bash: /storage/.config/remote1.conf: unknown operand
http://ix.io/1O3n
No work with remote.conf (is is magicsee n5 remote) and remote1.conf is ki pro remote
Now, i have check it with remote1.conf (ki pro) and remote2.conf (tr99 mini) and only work remote2.conf
remoteinfo show
bash: /storage/.config/remote2.conf: unknown operand
http://ix.io/1O3t
Anithing to try?
thanks
I only see 1 remote configuration in the log you have provided.
You need to copy both files and one should be named remote.conf and not remote1.conf.
Then name the second file remote2.conf.
I have tried it and i get the same result, only one work
remote.conf (1.4 KB) remote2.conf (2.6 KB)
These are the files
Try to put factory_infcode = 0 to the first, and factory_infcode = 1 to the second config file.
Now it work perfect. Thanks
