Hello @TheCoolest, I saw that you have two PVR IPTV Simple Client installed. Is it possible to install more than one and use different m3u list?
Thanks for your answer!
One is IPTV Simple, and the other one is IPTV Archive, it’s an extension of the IPTV Simple to add support for archive. You should be able to use both for 2 different playlists.
