So, unfortunately, my TV Box which is a HK1 Max, RK3328 and is S905X3, doesnt want to reboot into CoreELEC at all, my Android TV Box’s firmware is very crappy and of a bad quality, and using Kod is honestly not worth using on there, unless I use CoreELEC or something like that, but I couldnt never install CoreELEC on it, afterall my HK1 Max doesnt have much support form CoreELEC or things similar to it.
You see, what it does, is that the fact that it just reboots to CoreELEC whenever I had my SD Card put on with the installed CoreELEC and renamed TDB file, straight up reboots to the HK1 Max OS again, like if nothing’s there, like the SD card was empty, and using other options other than CoreELEC, straight up, just doesn’t work, like nothing, it is either a No SIGNAL thing or a black screen with white text and being able to type in with a plug in Keyboard in other altertatives to CoreELEC.
i just want to play Crash Team Racing, watch either Rocko’s Modern Life or Rick & Morty(Im a big fan of cartoons & anime), or read Reddit posts on my TV, that’s all I want, please. Im getting tired of just installing an OS, just to reveal that it doesnt work, like, for Real, Actually.
