Hi guys,
my MeCool M8S Pro+ just updated itself to 8.95.0 Unfortunately Kodi does not connect to my MySQL db anymore… the advancedsettings.xml is still in place and correct. I already tried rebooting, but this did not help
Any hint what might cause this?
Best, Alex.
If you are connecting to your network via DHCP try changing to a static IP and reboot.
Thanks, I just fixed it (I just came back to delete my post). It seems that the new build takes a little longer for the connection. After activating “Wait for network” everything works…
