Since yesterday, my N2doesn’t detect the mSD-Card, so I can’t boot CE anymore. With “MMC”-boot there is only the red light, no blue light.
In SPI boot, I have a blue light, can update Petitboot via LAN, but it doesn’t see the SD card.
Also I have no /dev/mmcblk1*
Tried different SD cards
Pin 1/2 has 3,3 / 5V
Is my N2 bricked? Or can I use eMMC a instead? Then I have to buy one
If it is bricked, which replacement can you recommend? Android-Box, Odroid, other… etc.
Thx
