N2 Odroid. Coreelec 22.0 nightly NTFS external HDD wont show in hardware as before
A real fan of the N2 and corelec. I had been using Coreelec 21.3 with external 2 NTFS HDD all ok.
Upgraded to Corelec 22.0 Piers nightly. Originally I plugged in a exfat 5TB external drive that worked well until it didnt! Did show in Coreelec/storage but nothing could be read/played. Changed to NTFS and that worked well for a while. Thinking I needed to check drive on a Windows PC I did a chkdsk check and repair, nothing was reported as a problem. Back connected to the N2 Coreelec 22.0 and while it does not show in Coreelec/storage after rebooting I get a message about a disconnecting 5TB drive.
Tried an old SD card with 21.3 and it just works, drive is present and all files playable. Back to 22.0 and same thing where drive is not recognised, drive is not present in the Coreelect/storage and yet is powered up and spinning.
Any clues how to reconnect the drive to Coreelec 22.0 please? Any linux commands to specifically address this issue?
thanks to all suggestions. (non received to 5/11/2026)
Edit: I installed the NTFS-3G package and its working again.
