The operating environment:
The Device : X96 Max Plus
The SOC : S905X3
OS: CE 9.2.5
Addons: CastagnaIT/plugin.video.netflix
The process that occurs:
Step1: Select VP9 decoding on the setting of addons.
Step2: Open the kodi log in Setting-System and display the CPU load percentage.
Step3: Open a movie with a resolution of 1080p or above
At this moment, you will find that the 4 cores of the CPU have uneven load distribution, some cores are 0%, and some are 100+%.
Cause the picture to freeze, drop frames.
I have backed up the video recording under unstable conditions, but because I was identified as a new user by this forum system, I couldn’t upload it.
In addition, if I play the same video on 9.2.2, the CPU will not be unstable.
