I’m assuming you mean the TvH Server?
Yes the one I quoted in your post.
If the TX92 is locked on to the tuners, then it is possible that the tuners are not available for the N2 to scan or otherwise use.
In case anyone else is having this issue with HDHR not finding channels here is the solution:
In the MUX Settings Constellation defaults to QAM/AUTO. Changing this to QAM/64 and the channels are now found.
As there’s 100 Muxes to change if some knows what file(s) this information is stored in I would appreciate knowing as it would make my life a lot easier.
Greg
Glad you finally found an answer to this!
Editing multiple muxes is pretty easy. Just select multiple files using shift, then click “edit” up at the top of the menu, ala this:
The editor will come up, but there are checkboxes beside every item because you’ve selected multiple files. Click the checkbox beside “constellation”; this will indicate you wish to change this particular item on all selected muxes, and then change it to QAM/64. Click Apply and they should all change.
Thanks once again. Did not know you could edit multiple entries like that.
Thanks.
