Recently installed CoreELEC on my h96 pro +.
All working fine, connects to WiFi but it’s not giving me the option to connect to Ethernet?
Anyone got a fix?
Thanks!
Anyone got a fix?
Thanks!
Try a different DTB with 100Mbit or 1Gbit LAN suffix
Thank you for your reply
I’m not really up on my CoreELEC lingo yet. What does DTB mean?
Sorry!
You mean a different build? Got ya!
If you don’t know what that means
What device tree did you use after burning the image to SD Card ?
Or did you not follow that step ?
Surprised it booted up.
You 905x3??
