Hi
I’ve installed CoreELEC(official):nightly_20200116(9.2) on my X96 Max(S905X3) but there is no GigE LAN connection (no link), wifi is fine. LAN works fine on Android so the h/w is OK.
CoreELEC:/sys/firmware/devicetree/base # cat coreelec-dt-id sm1_s905x3_4gCoreELEC:/sys/firmware/devicetree/base #
Any ideas ?
I thought the CPUs were X96 max - a S905x2 X96Max Air and Plus - a S905x3
Is yours a ‘Plus’ or an ‘Air’? or is there another variant I did not know about?
For the Air I use
CoreELEC:~ # cat /sys/firmware/devicetree/base/coreelec-dt-id sm1_s905x3_4g_1gbit CoreELEC:~ #
Note the 1gbit …
Yep, you’re using the wrong dtb.
Please what is correct dtb for X96 Max plus (S905X3) ?
