Hello. I am running the latest CoreELEC with input stream adaptive. Everything works fine, however it seems that Netflix is locked at 720p even though this device is more than capable to do 1080p. Is there a way to fix this?
No, been covered many times, there is no h/w decoding for the Netflix add-on so any setting over 720p and the device will stutter.
The CPU is around ~25% stable while playing back 720p. I can even overclock it and it will be lower, is there a way I could force it?
It has been tried by many users, and this device (as well as other S9xx devices) is just not capable of software decoding 1080p streams. Overclocking your C2 doesn’t solve this problem.
