ODROID C4 4k Doesn't play right
Hi all,
A couple of weeks ago my C4 randomly started having problems playing 4k videos. The video will freeze for anywhere between a few milliseconds to a few seconds and then play smoothly for a few seconds and then go back to freezing. It isn’t buffering. I didn’t make any changes to any settings, install anything new, or even touch the box before it started happening. Yesterday I tried a hard reset (I was on 19.2rc2) and it did not make a difference. I then updated to rc3 and no dice.
Everything else is functioning properly and there are no problems playing 1080p.
Any advice is much appreciated, thank you!
Devs will be able to look into your case only if you provide logs and maybe some sample of the videos.
https://discourse.coreelec.org/t/how-to-post-debug-logs/6494/2
